Battery help :3V to 9V/12V
Discussion in 'General Electronics Chat' started by ecjohnny, May 27, 2011.
  1. ecjohnny
    Thread Starter Senior Member
    Jul 16, 2005
    142
    Guys i need some help. How can i use a small battery cell 3V/1.5V to power up a 9V circuit? i found some voltage booster/multiplier and some IC for voltage step up. But most are driving up to more than 10V+ or requires aleast a 5V primary input. I decided to post this and get some help if anyone has an idea how can i go about doing it.
    i am modifying a 9-12V circuit to be as small as possible.(possibly size of a 3V coin battery). i need to find a small dc power choice to power up the circuit. the only solution i could think of is stacking 03x3V coin battery but the overall size bigger than expected or i could using a single 3V coin battery and amplify/boost/multiple it to achieve 9V.
    Any help would be appreciated. :)
  2. tom66
    May 9, 2009
    2,613
    214
    The LM2698 could do the job. But it is a surface mount only device. If you want a through hole device, look at MC33063A.
  3. iONic
    Nov 16, 2007
    1,422
    68
    What about the small 12V batteries used in car door Lock/Unlock devices for key chains.
    The would compare to 3 3V button cell batteries and need no circuit.
