Battery getting hot
Discussion in 'General Electronics Chat' started by Katherine1, May 19, 2013.
  1. Katherine1
    Mar 1, 2013
    24
    I did a circuit using 9V battery. However, the battery becomes hot very quickly. May I know what;s the problem?
    Attached is the schematic circuit. Is there a possibility that I have drawn wrongly which leads to short circuit?
  2. #12
    Nov 30, 2010
    16,655
    7,294
    You have the battery attached backwards.
    It probably killed the IC, too.
  3. PackratKing
    Jul 13, 2008
    850
    216
    I'll concur on both points...
  4. Katherine1
    Mar 1, 2013
    24
    Does that mean I just need to change the terminal of the battery and IC?
  5. DerStrom8
    Feb 20, 2011
    2,428
    1,329
    There are actually a few errors in that schematic, but #12 pointed out the main one. The battery is backwards. Also, pin 4 should be connected directly to +. Right now you're "resetting" the chip at the same time that you "set" it. You can connect it directly to positive in order for the chip to time out on its own, or you can connect it via a separate pull-up resistor to a second switch, that when pressed would ground it and reset the chip before the timing period ends.
    #12 likes this.
  6. DerStrom8
    Feb 20, 2011
    2,428
    1,329
    No, you need to connect the entire battery the other way around (reverse the + and - wires on the battery).
  7. #12
    Nov 30, 2010
    16,655
    7,294
    Thanks DS8. I gave it a quick scan and still missed the reset pin. Many eyes catch more mistakes.
    DerStrom8 likes this.
  8. Katherine1
    Mar 1, 2013
    24
    Oh really, thx for pointing out for me. This is my first time doing a circuit. I'll try to reverse the battery and connects pin 4 to the positive. One more problem, the switch i use is a 4 leg push button (https://www.sparkfun.com/products/9190) . when i press it, it pops back. Does that mean it cant be used in my case?
  9. DerStrom8
    Feb 20, 2011
    2,428
    1,329
    I see you're using that pushbutton as the trigger. That is exactly the type of button you want. The 555 will be set with only a single input pulse. Pressing and releasing the button will be perfect for the trigger.
  10. LDC3
    Apr 27, 2013
    920
    160
    Another problem is that you are putting about 8 V on the speaker (which is usually 8 ohms). This would result in a 1 amp current. Much more than the battery can supply. I think a typical 9 V battery can supply 0.1 amps for a very short time.
  11. Wendy
    Mar 24, 2008
    20,772
    2,540
    The transistor has no current limiting for the transistor. That is a dead short to the output of the 555.
    A transistor BE junction looks like a diode, a forward biased diode. Put a 1KΩ resistor between pin 3 and the Base of the transistor.
  12. DerStrom8
    Feb 20, 2011
    2,428
    1,329
    Oops, forgot to put that in my post listing the problems. Thanks Bill :p
  13. DerStrom8
    Feb 20, 2011
    2,428
    1,329
    It should still work though, it just won't be as powerful.
  14. timescope
    Member
    Dec 14, 2011
    298
    44
    BPR1 could be one of those piezo buzzers with a built in oscillator that only requires a DC supply to produce a sound (a cylindrical black thing with a hole on top and two pins on the base)
    The circuit is configured as a re-triggerable monostable by connecting the reset and trigger together: when SW2 is pressed, the capacitor is discharged and a new timing cycle begins when it is released.
    One possible problem would be the leakage current of the 1000uF capacitor : if it is too large, pin 6 will never reach the threshold of 2/3 of the supply voltage.
    Timescope
  15. LDC3
    Apr 27, 2013
    920
    160
    Well if this is the case, most piezo buzzers have a current limit under 50 mA. With no other resistance, the current would be way to much for it.
  16. timescope
    Member
    Dec 14, 2011
    298
    44
    mouser piezo buzzer datasheet
    These devices have an inbuilt transistor oscillator circuit that regulates the current. The above device consumes 8mA (max) at 9v and can be used from 3v to 30v.
    Timescope
  17. Katherine1
    Mar 1, 2013
    24
  18. timescope
    Member
    Dec 14, 2011
    298
    44
    Use the "Estimated Service" information in the datasheet.
    First you must implement the corrections suggested and get the circuit working properly then measure the current consumption.
    1. Correct the battery polarity
    2. Add resistor in series with the transistor base
    3. Replace the 555 timer as it is probably damaged
    Timescope
  19. LDC3
    Apr 27, 2013
    920
    160
    From the datasheet, if the load is 620 ohms with an average voltage of 7 volts, the average current would be about 11.3 mA. A load of 180 ohms has an average current of about 38.9 mA.
