I am working on a RF portable module that operates as a transponder.. works @ 2.4Ghz, battery operated...every 5 or 10min once it wake's up, transmits few bytes of data n goes back to sleep mode.... its spec >> 45 mA peak transmit current n sleep current < 10uA... the device is expected to work for 5 years..... i wanted some info on wat kind of battery to use n any modifications required ?? (operating voltage 3.3v) any kind of info related to this would be helpful...
Thank you
Thank you
