I have studied many battery sulfator curcuit diagrams. What I concluded is that they provide a high voltage, high frequency (resonent) and low duty cycle pulses to the battery to break down the sulfate deposits. I guess the complexity in these circuits is that they use the power of battery which is under test. Am I right till? Ok now what if I I build a 1KHz oscilator with low duty cycle (about 10% and with all adjustable parameters) and send this frequency to a ferrite core step-up transformer through a power FET. I can use an additional power source instead of battery under test. (Please see attachment for block diagram). Will it start desulfating the battery? If it is ok then what should be the ratio of transformer. I mean what peak voltage should be at O/P ? Please help me in this regard. Thanks.
