Battery cut-off when discharging
Discussion in 'The Projects Forum' started by nickbell, Mar 19, 2014.
  1. nickbell
    Mar 19, 2014
    First let me say I have little or no electronics background.
    I am hoping to build a battery discharger, and I want this unt to cut off at 3.3v. (a little background here, I race radio controlled cars using 3.7v lipo batteries)
    I somewhat understand and can read these circuits from my engineering background, however I have no earthly idea what I need to change to achieve this cutoff.
    I'll be starting at 3.8 volts with approx 30amp load
    thanks for the help
    Nick
  2. Alec_t
    Sep 17, 2013
    5,980
    1,138
    You should start your own thread, not hijack someone else's.
  3. bertus
    Administrator
    Apr 5, 2008
    15,806
    2,390
  4. magnet18
    Dec 22, 2010
    1,232
    125
    you just want it to shut down entirely? or do something like send out a warning?
    Racing RC cars, is weight a factor?
    the simplest route (in my opinion), is get an arduino or other uC(microcontroller), measure the voltage, and shut it down with a relay (or use a transistor somewhere in the control circuitry to inhibit the thing)
    just my opinion, I'm a fan of arduinos though
  5. Alec_t
    Sep 17, 2013
    5,980
    1,138
    Is this discharger an in-car or out-of-car thing? Do you have a power supply other than the Lipo available for the discharger?
  6. inwo
    Nov 7, 2013
    2,435
    315
  7. magnet18
    Dec 22, 2010
    1,232
    125
  8. inwo
    Nov 7, 2013
    2,435
    315
    I didn't understand this to be an "on board" device.:confused:
    "I am hoping to build a battery discharger,"
    Seems more like a battery tester.
  9. magnet18
    Dec 22, 2010
    1,232
    125
    i took it as an onboard device that shuts the car down when the batteries hit a certain point, we should probably wait for op input rather than running away with this though
  10. burger2227
    Member
    Feb 3, 2014
    192
    24
    Lithium batteries can be ruined if discharged too far. I'd assume he wanted something to avoid that.
    He's probably wondering where his thread went...
