I need some help with a battery chemistry choice. My project requires that my battery be in an enclosed box that will be out doors during the summer months of areas like S. Florida and Arizona. I will try to shade the battery box from direct sun light, but I'm sure the temps will still reach several degrees over 100F. It needs to be 12V, approximately 9Ah capacity and it must have a low self-discharge rate. Lead-acid will probably operate OK, but its self discharge rate is too high; we want to go at least several months between recharges. Lithium Ion or LiFe looks good as far as self discharge, but I'm concerned about the temperature. Can anyone suggest a battery chemistry that would be best? Rechargeable is preferred, but disposable is OK if the cost is relatively low.
