Battery Charging
Discussion in 'Homework Help' started by akifnadeem, Nov 11, 2010.
  1. akifnadeem
    Apr 9, 2010
    How can we calculate the timing of a battery with his voltage ratting of 1.2V & with 2300mAh.??
  2. thatoneguy
    Feb 19, 2009
    Most battery chargers cut off based on delta T or delta V when charging with a constant current. When the temperature starts rising quickly the battery is fully charged (delta T). When the Voltage stops rising, it is charged (Delta V).
    1.2V@2.3AH sounds like a newer AA or C/D cell.
    What is the battery chemistry? The first line above covered NiCd/NiMH chemistry.
