Battery charging
Discussion in 'General Electronics Chat' started by Maverick77, Mar 2, 2009.
  1. Maverick77
    Feb 5, 2009
    I wish to charge two different types of batteries with same volt (12v) using a inverter charger and solar charger simultaneously.
    Both inverter circuit and solar charger have their controller.I also want to use the batteries via the inverter when it mite still be charged with the solar charger.
    Is it possible for me to use the batteries without damaging any of my components?
  2. thingmaker3
    Retired Moderator
    May 16, 2005
    5,072
    6
    If each battery has its own charge controller, they will be okay. Use steering diodes to keep your supplies from trying to power each other.
  3. Maverick77
    Feb 5, 2009
    Thanks. Ya each battery has its own charge controller but i will be using both solar charger and inverter charger simultaneously to charge both type of batteries. Wil the batteries of lesser ampere hours be worn out quickly??
  4. Maverick77
    Feb 5, 2009
    Further i will be using them whn they are being charged. So ne probl with currnt??
  5. thingmaker3
    Retired Moderator
    May 16, 2005
    5,072
    6
    I think you will find you are using the chargers rather than the batteries.
    And a happy frumious bandersnatch to you as well, Mr. Carrol!:confused: This is an English language forum, if you please.
