Hi, I want to know how much current is required for charging of a 12V, 140AH inverter battery...
S Thread Starter shabeeb Joined Nov 23, 2008 1 Nov 23, 2008 #1 Hi, I want to know how much current is required for charging of a 12V, 140AH inverter battery...
hgmjr Joined Jan 28, 2005 9,027 Nov 23, 2008 #2 I have moved your post to its own thread. This will give your question the visibility and attention that it deserves. In the future, we request that you launch your own threads rather than append your question to the end of an existing thread. hgmjr
SgtWookie Joined Jul 17, 2007 22,230 Nov 23, 2008 #3 It depends upon how badly it's discharged. If it's completely discharged, I would charge it at a rate of 14A for 10 hours, and then establish a proper float charge voltage. Float charge voltage is dependent upon temperature and battery construction.
