Battery charging and monitoring circuit
Discussion in 'The Projects Forum' started by Getafix, Oct 9, 2008.
  1. Getafix
    Oct 9, 2008
    Hi I am designing a circuit that is battery powered but which also has a mains supply to enable the battery to be charged. Can anyone recomend an IC or method to enable me to charge and control the charging of the battery to prevent the battery being damaged.
    All help and advice greatly appreciated
    Getafix
  2. triggernum5
    May 4, 2008
    216
    Most chargers use a thermistor to monitor completion if anything at all..
  3. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    The kind of battery involved is pretty critical to any answer.
  4. Audioguru
    Dec 20, 2007
    9,411
    896
    Most semiconductor manufacturers make battery charger ICs that can be switched to charge most types of rechargeable battery.
