battery charger
Discussion in 'The Projects Forum' started by harikanaidu, Nov 28, 2014.
  1. harikanaidu
    Nov 28, 2014
    76
    hi can any give me the suggestion for designing a circuit that charges battery when the power is present and it automatically stops after charging fully....and it should be discharged only when there is no power....output should be 5V,1amp
  2. harikanaidu
    Nov 28, 2014
    76
    Hi Nandu,
    V/AH rating of the battery is 12v/1.35Ah
  3. harikanaidu
    Nov 28, 2014
    76
    Lead acid battery
  4. Dodgydave
    Jun 22, 2012
    5,150
    769
    So do you have a 12v battery and it gives out 5v to your load, or what?
  5. bertz
    Member
    Nov 11, 2013
    239
    31
    1. What do you mean by "when the power is present"? Does this refer to input power to the charger or when the battery is under load?
    2. What does "discharges only under power" mean? Do you mean that the battery disconnects from the load during charging?
    3. You tell us that the battery is a 12 volt lead-acid rated at 1.2 Ah. A charging circuit delivering 5 volts cannot charge the battery. The charging voltage must be greater than the peak voltage od a fully charged battery which is around 14 volts.
    4. What is the device being powered by the battery?
  6. harikanaidu
    Nov 28, 2014
    76
    I want to use my internet modem even at the time of power cut.....For that i want to use power from the battery ....At the time of power cut modem is powered with this battery...Modem requires 5V,1amp
  7. tcmtech
    Nov 4, 2013
    2,111
    1,750
    I suggest looking for a USB battery. A quick internet search will tell you the rest.
  8. harikanaidu
    Nov 28, 2014
    76
