Battery Charger
Discussion in 'General Electronics Chat' started by banzai, Nov 6, 2014.
  1. banzai
    Jan 3, 2014
    71
    Hi
    I got my eyes on a newly installed Smart battery charger for a battery bank the other day. I got the chance to open the charger cabin door, but much of the parts where behind a protection glass, so i wasn't able to read any part numbers. what got me wondering is how is these chargers able to adjust there voltage in such a wide range. I am sure it's not transformer taps, would it be IGBT's ???
    The charger is a 110VDC-out and 380VAC in. Voltage range is 90-140VDC if i recall this right.
  2. MikeML
    Oct 2, 2009
    5,451
    1,066
    It is likely a Switch-Mode Power Supply that is controlled-current when the batteries are initially discharged, and controlled-voltage as the battery bank approach full charges state. It likely uses a MCU to implement a sophisticated multi-state charging algorithm.
  3. banzai
    Jan 3, 2014
    71
    How is the voltage adjusted/controlled. Is it trough a IGBT by adjusting its gate voltage ?
  4. MikeML
    Oct 2, 2009
    5,451
    1,066
    The switch could be anything, but most likely IGBT or NFET. However, it is a SMPS, so the switching devices are driven with PWM.
  5. banzai
    Jan 3, 2014
    71
    So it is rapid ON/OFF we are taking about (PWM). I thought they varied the gate voltage in order to set the required output voltage, but that would waste much power.
  6. banzai
    Jan 3, 2014
    71
    So is it simply a switched mode power supply witch high current, high voltage mosfets or IGBT's and a smart controlling circuit ?
  7. MikeML
    Oct 2, 2009
    5,451
    1,066
    As I said back in post#2, it is a SMPS, but it is anything but simple...
