Is there anything complicated about testing the battery charger for my drill? I put the leads of the meter on two of the three contacts - and set on amps. Is this the right approach? I got a few milliamps. Is the third contact a ground? Does the charger need to be under a load or anything like that? I didn't look to see what the output is supposed to be because I wasn't sure if I was doing it right at all.
