battery charger output
brian3222
Joined Jul 29, 2013
What kind of voltage should a battery charger put out when you test it at the clips with a volt meter?
at 12v/10 amps I get around 10.5 volts
at 12v/2 amps I get around 9.5 volts
Not on the battery, just hooking the clips to a VM.
MaxHeadRoom
Joined Jul 18, 2013
28,698
You may get all kinds of misleading readings without a battery connected, depending on the technology used, the one I built some time ago requires to see a battery voltage/load before you see any reading.
Max.
wayneh
Joined Sep 9, 2010
17,498
The unloaded readings don't mean anything. Try attaching a lightbulb or attaching to a battery. You should get ~14V
janu
Joined Mar 1, 2013
9
Dear Sir/Mam.,
We are using the LTC2941 IC for the Li-ion battery level indication(3.6v) and also use the charging IC(LTC4057)with AT32UC3A3 controller.
Just now i made the hardware connection based on this.
Then i need to connect the LED for the battery level charging and discharging based on percentage.
How can i made the code for the above concept.
Please clarify this as earlier...
