I want to charge two Lithium ion cells using a 12V,1A adaptor.The power supply should charge the battery and also supply current to the load.
When power supply is not available the batteries should discharge through load.The batteries should last atleast 1hour 30minutes.Can someone suggest a schematic including power path management.Thank you.
Load requirements:7.5V,500mA
Battery specification:3.6V,750mAH.
