battery Charger for 12v
Discussion in 'General Electronics Chat' started by indika perera, Feb 22, 2015.
  1. indika perera
    Mar 7, 2013
    30
    dear all,
    i have created following circuit as a 12v battery charger but its output voltage is higher(some what 25v) than the expected voltage which is around 14.5V . So any body please explain is their any faults of this circuit and how to correct it..
    Big thanks.
    indi
  2. MrChips
    Oct 2, 2009
    12,624
    3,451
  3. indika perera
    Mar 7, 2013
    30
    thx 4 the reply MrChips..so do u think is their any prob?
  4. ScottWang
    Aug 23, 2012
    4,925
    777
    1. Check the pins connections of LM350.
    2. Re-check all the wires connections.
    3. Check Q2, Q1, do they work?
    4. Does the D2 LED lighting, does c voltage of Q2 close to gnd?
  5. indika perera
    Mar 7, 2013
    30
    thx..scottwang...yes i have checked several times..my doubt is that lm350 voltage regulator require proper resistance combination through it pins to necessary drop of voltage.. another thing is that variable resistant is set to adjest voltage but in my case it is no longer affect anything to the output..
  6. ScottWang
    Aug 23, 2012
    4,925
    777
    How is the point 4 that I mentioned, did you measure it, and how is the LED?
  7. indika perera
    Mar 7, 2013
    30
    led blinks..but once i checked the battery terminal from the multi meter the led again blinks..that means i does not has some resistance..me be it blinks for higher voltage may be 25v fortunately not burn out.
  8. ScottWang
    Aug 23, 2012
    4,925
    777
    How is the input voltage, Vdc, DC pulse, how high?
    What are you trying to charge the battery, Vdc, DC pulse?
  9. indika perera
    Mar 7, 2013
    30
    input 24v dc output expected 14.5v but output was 25v..that the issue..
  10. ScottWang
    Aug 23, 2012
    4,925
    777
    Where is the Vin dc came from?
    It looks like the filtering has some problems, do you have O'scope to measure the Vin?
  11. ronv
    Nov 12, 2008
    3,393
    1,452
    Measure the voltage at the base and emitter of the BD140.
  12. indika perera
    Mar 7, 2013
    30
    dear scottwang dc input will be given from a 3A transformer with 4 half way rectifiers..dc input has no issue it wil around 17v-24v range NOT above that..
    need some help
    no i havn't O'scope
    thx
    indi
  13. indika perera
    Mar 7, 2013
    30
    Thx for reply..so what to do with measuring above voltage..i'm not expert in electronics..any clarification please
  14. Dodgydave
    Jun 22, 2012
    5,143
    768
    Short out the C/E of the bd140, what voltage is at the output, is the led on?
  15. indika perera
    Mar 7, 2013
    30
    thx..dodgy... i am actually away with it just kept it in a box..and trying to figure out the prob with this forum..you sure is not there any harm for bd140 while shorting..ok i will try..thx
  16. indika perera
    Mar 7, 2013
    30
    i search that lm750 module on ISIS simulating software but coould not found..plz anybody know good software with huge database for circuit simulating..
    thx indi
  17. Dodgydave
    Jun 22, 2012
    5,143
    768
    lm350 is the one in your circuit???
  18. indika perera
    Mar 7, 2013
    30
    yep..
  19. indika perera
    Mar 7, 2013
    30
    anybody plz help me..
  20. ronv
    Nov 12, 2008
    3,393
    1,452
    Do you know which pins on the BD140 are the base and emitter?
