Wow !that's 12V......There are some neat videos on the subject, this is just one of many...
http://www.youtube.com/watch?v=RQjudHKh-bI&feature=fvst
Shoot, back when I was a kid I used to make nitroglycerin in my home lab, pack it tightly in a test tube with a cork stopper then throw it up in the air over the street and run like hell. Used to make home made rocket engines as well, odd how the potassium nitrate + sugar, melted down then poured into a 12 gauge shotgun shell with the primer removed would replace the D size Estes engines.Probably not a good idea to explode anything in your country R!f@@. You may just disapear!!! Then what will we do???
That's why it's fun to scuba dive at the Maldives. You find so much strange things in the sea.So sea is the only way.
Agreed. It is nice to dive wrecks, but not landfills, or SEA-fillsnerdegutta said:Please, don't use the sea as you garbage can.
One of the worst whippin's I got growing up was making those rockets. /but we used empty 30-06 cases. Was melting the mix over a alcohol burner in my bedroom and a little bit got on the edge of the ladle a caught fir , it sparks a little when it burns and that caught the cigar box of the mixture on fire, and that my desk and that the wall. Once the mix starts burning it has to burn its self out. After the fire dept. and cops left, my Dad started in on me.<snip> Used to make home made rocket engines as well, odd how the potassium nitrate + sugar, melted down then poured into a 12 gauge shotgun shell with the primer removed would replace the D size Estes engines. <snip>
If you do:Then I will blow it.
How big is this island, again...?...where no one will be around for a km or so.
RIFAA! Get that thing away from your HOME!I just realize that the battery was not there where I put it.
Went through the whole trash to find it in the bottom.
Lucky it was still intact.
by Robert Keim
by Jake Hertz
by Don Wilcher
by Jake Hertz
