Battery Backup for HRV Programmable Timer
Scavenger
Joined Jan 5, 2005
19
I bought a programmable timer for my HRV. It turns out the timer doesn't have battery, so when the power goes out the programming is lost. Since the power to the timer is coming from the HRV, how would I go about adding a battery backup to the timer. There are three wires going from the HRV to the timer. A coworker said the three wires would likely be power, signal, and ground - is that true? I measured the voltage across each pair of wires, when the timer is switched off (at the timer), and got these values: A-B: 4.53V A-C: 4.78V B-C: 0.25V. When the timer was switched on, the voltages were: A-B: 4.53V A-C: 4.88V B-C: 0.36V. At that time it was running the HRV fan on low speed. What sort of circuit would I need to ensure the following:
  1. I don't lose the programming
  2. I don't fry the timer circuitry
  3. I don't fry the HRV circuitry
  4. I don't blow-up the batteries
I'm an electornics rookie, so don't assume I know anything.
Thanks.
Richard
Scavenger
Joined Jan 5, 2005
19
It's time to fire up the HRV for the winter. Still looking for help on what I'd need to provide battery backup for the timer.
Thx.
SgtWookie
Joined Jul 17, 2007
22,230
Are you talking about a "heat recovery ventilator"?
Do you have a manufacturer and part number/model number for this timer you bought?
