batterry discharge and time
Discussion in 'General Electronics Chat' started by superway, Aug 30, 2013.
  1. superway
    Thread Starter Active Member
    Oct 19, 2009
    128
    I have a 12vbattery 7.2AH. If I loaded it 7.2A, the battery will run out within 1 hour, is that right?
    If so, If I loaded it 450mA, will the battery run out in 16 hours?
    Thanks for help
    -ken
  2. GopherT
    Nov 23, 2012
    6,326
    4,054
    Approximately, but never run it completely out or it won't recharge. Also, if you have a constant resistance, the battery voltage will drop as the battery charge falls. That means less and less current will flow.
  3. JoeJester
    Apr 26, 2005
    3,403
    1,227
    You might note on your battery that it specifies the 10 or 20 hour rate. You might consider a circuit to disengage the load when the battery reaches 10.5 Volts. Of course, that circuit will consume some energy from the battery, lowering the time available for the load.
