batteries in series, different discharge rates
Discussion in 'General Electronics Chat' started by strantor, Jun 8, 2011.
  1. strantor
    Thread Starter AAC Fanatic!
    Oct 3, 2010
    4,302
    1,989
    Ok, i will set up an example:
    let's say you take 4 12V batteries and put in series to run a 48v motor continuously, (assuming they are all 4 exactly the same) the 4 batteries should all discharge at the same rate, correct?
    Now, you tap between the first and second battery and add a 12v motor there (in parallel with the first battery), will the first battery discharge faster than the other 3?
  2. tom66
    May 9, 2009
    2,613
    214
    Yes, and doing so is a bad thing because it can lead to cell reversal: a particular cell can have a negative voltage forced across it if it is discharged quicker than the other two cells. See the screenshot of a simple capacitor divider showing a similar effect. The second cell from the bottom has been discharged 100x faster than the other cells and has a -63mV potential across itself (look at the cell tap voltages), which would ruin almost any type of battery. In some packs, this action can even overcharge other cells in the battery, damaging them too.
  3. iONic
    Nov 16, 2007
    1,422
    68
    Although not the most efficient solution, but using a 12V Voltage Regulator (LM7812) across the 48V supply (the 4 batt's in series) would get around the issues presented above.
    strantor likes this.
  4. strantor
    Oct 3, 2010
    4,302
    1,989
    cool drawing? what program did you use? I usually use paint.
  5. tom66
    May 9, 2009
    2,613
    214
    A 7812 will not be happy with 48V and will likely break down, allowing the full 48V to hit the 12V motor.
    Not to mention the inefficiency of that solution. Per amp the motor wants, 36W will be dissipated. So it will be less than 25% efficient.
  6. iONic
    Nov 16, 2007
    1,422
    68
    I used an old version of Paint Shop Pro, back when it was Jasc Inc.
    Wasn't sure what the max Vin on the 7812 was, but you are probably right about your assessment.
  7. tom66
    May 9, 2009
    2,613
    214
    Max Vin is 35V, according to this datasheet. Some 7824 regulators can handle 40V input.
  8. strantor
    Oct 3, 2010
    4,302
    1,989
    Ah, I remember that, I used to use Jasc Paint Shop Pro 7, then 9. It was alot easier to use than the new ones IIRC.
