basics
Discussion in 'General Electronics Chat' started by bigsteve-4, Jun 24, 2013.
  1. bigsteve-4
    Jun 24, 2013
    I need to find what will be a simple answer for all of you guys, I teach and fly radio control aircraft so when things are working I just switch on and that's it. but we use batteries to run stuff. my question is, what resister do I need to use to make a 2volt battery run a 1.5v glow plug? this is in a glow engine. we use pre-made circuit boards to run starter motors and glow plug. but I do have loads of these batteries so if I could make a load of these battery connecters all the guys a teach could have a cheep glow plug starter, thanks for this guys
  2. Wendy
    Mar 24, 2008
    20,772
    2,540
    You would probably need a simple voltage regulator to have best performance. Any idea what current a glow plug draws?
    Something like this...
    though you may want to add a few capacitors for stability.
  3. Shagas
    May 13, 2013
    802
    74
    Rc glow plugs draw a few amps
  4. bertus
    Administrator
    Apr 5, 2008
    15,799
    2,385
