basic
Discussion in 'General Electronics Chat' started by radha, Jan 5, 2011.
  1. radha
    Jan 5, 2011
    how to convert 10V dc to 5V dc , besides using voltage divider and zener diode ..??
  2. Kermit2
    Feb 5, 2010
    3,837
    961
    op amp
    same setup you would use to turn 10V into a +5 and -5 volt supply.
  3. radha
    Jan 5, 2011
    cn u plz explain me dat as well or if you could give ne link where i would find d above..??
  4. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    If you are speaking of a power source, a 7805 voltage regulator might be superior.
    Can you say what to application is?
  5. Kermit2
    Feb 5, 2010
    3,837
    961
  6. edgetrigger
    Member
    Dec 19, 2010
    133
    19
  7. R!f@@
    Apr 2, 2009
    8,785
    771
    7805 is the best approach if load max's at 1 Amps.
  8. blueroomelectronics
    Jul 22, 2007
    1,758
    98
    As long as you have a large heatsink. Dropping 10V to 5V @ 1A is 5W its got to dissipate.
  9. radha
    Jan 5, 2011
    thnx all..
