basic
Discussion in 'General Electronics Chat' started by knkarthi, Aug 26, 2009.
  1. knkarthi
    Mar 14, 2009
    which is the best method to understand concepts?
    conventional or electron flow?
  2. Wendy
    Mar 24, 2008
    20,772
    2,540
    I tend to go with physics, but that is a preference. Both work, which is what is important.
    The reason I prefer to go with physics is later on, when the really advanced concepts come along, I have the model firmly in my head.
  3. Ratch
    Mar 20, 2007
    1,068
  4. rspuzio
    Jan 19, 2009
    77
    Use whichever one you feel the most comfortable with. As long
    as you are consistent and don't change your definition halfway
    through a calculation, it doesn't matter which choice you use
    because either way, you will obtain the right answer.
    Personally, as a physicist, I am used to the conventional current
    (positive current is the direction in which a positively charged
    object moves) so I use that.
