Basic transistor switch question
Discussion in 'General Electronics Chat' started by bbucky, Oct 23, 2007.
  1. bbucky
    Oct 16, 2007
    6
    I understand that current through the base electrode will trigger a transistor to act like a switch. Is there a way to calculate what is the minimum current (or voltage?) that is required to trigger that switch?
    On the datasheet I see a "base-emitter saturation voltage" with 0.6V under "min". Is that it?
  2. niftydog
    Jun 13, 2007
    95
    If you want the transistor to be fully on (saturated) you must ensure that the current flowing into the base is at least the maximum collector current divided by the typical current gain (Ic / hfe). You must also be careful to limit the collector current or else you will damage the transistor.
    The 0.6V is the voltage that will be present across the base emitter junction when the transistor is biased on.
  3. bbucky
    Oct 16, 2007
    6
    thanks for the info. I'll see if I can make it work.
