Basic Signal Detector using MOSFETs
Discussion in 'General Electronics Chat' started by chboizz1, Apr 13, 2016.
  1. chboizz1
    Aug 10, 2015
    11
    Hello, I am trying to design and build a basic signal detector using MOSFETs because they are more compact than resistors, capacitors, and conductors. I was wondering if anyone hear has any suggestions on how I can start my approach on this project. The original thought I had was to simply look up a simple Field Strength Meter (attached below) and simply replace the capacitors in the circuit with properly biased MOSFETs so that they can be used effectively as capacitors. This approach seems too naive, if anyone has a more refined approach please feel free to tell me.
  2. TheButtonThief
    Feb 26, 2011
    219
    38
  3. bertus
    Administrator
    Apr 5, 2008
    15,802
    2,388
    removed
  4. AnalogKid
    Distinguished Member
    Aug 1, 2013
    4,696
    1,297
    Why do you think a MOSFET can replace a capacitor? they are very different components. If anything, a MOSFET can be made to emulate a variable resistor, not a capacitor.
    Your question is not clear. What is it you are trying to do? Why is compactness important?
    ak
  5. chboizz1
    Aug 10, 2015
    11
    I am actually wondering if its even plausible(rational) to design a basic signal detector with only an antenna and MOSFETs. The idea of compactness is so that it can possibly fit on some sort of small chip with a printed antenna.
  6. Kermit2
    Feb 5, 2010
    3,851
    967
  7. chboizz1
    Aug 10, 2015
    11
  8. AnalogKid
    Aug 1, 2013
    4,696
    1,297
    If you are talking about replacing the traditional detector diode with a MOSFET, I think the FET threshold voltage will be a problem. Note in one of the linked schematics there is a 3 V battery and a pot to bias the FET to the edge of conduction. Are you going for a zero-power radio, or is a battery allowed? Also, note that there already are many single-chip AM radio parts on the market. Most implement the standard super-het method, but there also are strange critters such as the 3-pin ZN414.
    ak
  9. chboizz1
    Aug 10, 2015
    11
    Battery is perfectly fine, although no battery is as well.
