basic relay info required
Discussion in 'General Electronics Chat' started by mathi123, Aug 19, 2013.
  1. mathi123
    Aug 19, 2013
    I am trying to use a relay for the first time.
    I bought 2 of these and I want to use them in my circuit (5V control voltage).
    However, the relay has 6 pins? The datasheet says it is a Form A, so it should have 4 pins?
    The wiring diagram shows that pin 2 and 5 are connected, but should I connect these in my diagram, or are they internally connected?
  2. odinhg
    Jul 22, 2009
    65
    15
    It looks like pin 2 & 5, and 3 & 6 is connected internally. If you look at page 2 of the PDF on the page you posted, there is a better drawing.
    mathi123 likes this.
  3. strantor
    Oct 3, 2010
    4,302
    1,989
    Cool Relay. They do that so you have the option to use the pins on the bottom (soldered to board) or the pins on the top (connected via female spade terminalsw/ wire leads)
  4. mathi123
    Aug 19, 2013
    Don't quit get that.
    The top and bottom is symmetric, right?
  5. strantor
    Oct 3, 2010
    4,302
    1,989
    You have 2 options. You can connect to the top of the relay like this:
    Or you can connect to the bottom of the relay like this:
  6. odinhg
    Jul 22, 2009
    65
    15
    I don't think it actually does have blade connectors on top. It just looks like that in the drawings, but I think it tries to visualize that the pins are tied together internally :)
  7. MaxHeadRoom
    Jul 18, 2013
    10,851
    2,521
    Thought of doing a bit of reverse engineering with an Ohm meter?
    Max.
  8. cornishlad
    Member
    Jul 31, 2013
    196
    25
    As this is a relatively high current relay for a pcb so 2&5 and 3&6 are connected internally to allow for lower resistance and better soldered connection down to the pcb tracks.
  9. strantor
    Oct 3, 2010
    4,302
    1,989
    Sure looked like it to me. Check out the other documents. It gives dimensions for the spades and everything.
  10. odinhg
    Jul 22, 2009
    65
    15
    Yes you are right. Sorry, didn't see that drawing.
