BASIC problem with Transistor as switch
Discussion in 'The Projects Forum' started by gnolivos, Jul 15, 2011.
  1. gnolivos
    Jul 14, 2011
    18
    OK, this is a very basic step I am taking, to test a larger circuit. Since my circuit wasn't working as expected, I stripped it down and started with just the transistor switch design.
    I built this circuit, and I am getting a very very low current out of the emitter just downstream of the resistor. About 64uAmp (microAmp) instead of 35mAmp (milliAmp).
    I can't figure out what's wrong, can someone please enlighten me? The transistor is a BC547 NPN.
    Circuit LINK
  2. CDRIVE
    Jul 1, 2008
    2,223
    99
    Your link doesn't bring us to your schematic.
  3. kubeek
    Sep 20, 2005
    4,691
    806
    I see Ib 350uA and IC 35mA. What is the problem?
    (Except that the circuit is not a switch but a voltage follower, which acts kinda like a switch but not really)
  4. gnolivos
    Jul 14, 2011
    18
    Well, what should the current out of E be? According to the circuit, including the 30ohm resistor, it should be around 35mA (same as IC). I am getting extremely dim LEDs, and measuring only 64uA into the pair of LEDs... why?! :confused:
  5. kubeek
    Sep 20, 2005
    4,691
    806
    What is the Vf of your LEDs? The circuit gives only Vb-0.7V output to the 30ohm resistor.
  6. gnolivos
    Jul 14, 2011
    18
    Fwd Voltage of the LEDs is 1.8V.
    Also, reading your comment below... I thought the voltage coming into the base Vb was only responsible of saturating the transistor, and opening it up so that the Voltage at the Collector would become the 'main' circuit feeding through the emitter and to the resistor, down to the LEDs...?
  7. kubeek
    Sep 20, 2005
    4,691
    806
  8. gnolivos
    Jul 14, 2011
    18
  9. gnolivos
    Jul 14, 2011
    18
    Kubeek,
    Would this configuration make more sense for a switch, triggered by my 3.3V source?
    CIRCUIT #2
  10. kubeek
    Sep 20, 2005
    4,691
    806
    No, the simulators is quite right, it shows exactly what you told it to. There has to be something different from the actual circuit.
    Anyway, if you are just trying to power two leds, based on a 3.3V signal, look at this picture: http://sub.allaboutcircuits.com/images/03098.png
    R1 would be about 470ohm. You should have a resistor separate for each led, do you want 17.5mA through each?
  11. kubeek
    Sep 20, 2005
    4,691
    806
    About right, but you need the 470ohm resistor in series with the base, and swap the battery with the diode.
  12. gnolivos
    Jul 14, 2011
    18
    Isn't it equally correct to add a single resistor (half the ohm), before the parallel LED branch?
    Yes, ~17mA for each is about where I want it.
  13. kubeek
    Sep 20, 2005
    4,691
    806
    It is not good to parallel LEDs, their Vf can be different so they will have different brightness because one will use most of the available current. You should count with cca 0.2-0.4V drop on the saturated transistor, so 150ohm for each LED should be ok.
    I think that putting the leds in series would be too close for the 4.5V supply.
  14. gnolivos
    Jul 14, 2011
    18
    Thanks for all your help.
    I think my problem is that the 3.3V signal is actually from a motion sensor (PIR). I think the issue may be that the 3.3V output trigger has a very low rating on the output current... probably too low into the transistor's Base, and therefore the entire circuit is feeding a much lower current to the LEDs.
    Here is the spec: http://www.futurlec.com/PIR_Module.shtml
    So, my solution will likely be to use a ~ 3V relay if I can find one. DO you think a relay can properly operate from the low current 3.3V trigger output, without amplification?
    Thanks!
  15. Pencil
    Dec 8, 2009
    271
    38
    I'm coming in to this late, correct me if I am not understanding.
    You have a PIR module.
    The output from PIR module is 3.3V, unknown output current.
    You wish to power 2 LEDs with a 1.8 Vf at 17mA each for testing purposes.
    Your supply voltage is 4.5V.
    The "datasheet" on PIR module shows it driving an NPN transistor.
    Have you tried hooking it up as I have shown in attachment?
    Are you sure you are connecting the pins on the transistor properly?
    I have attached a datasheet for BC547 transistor for reference.
  16. gnolivos
    Jul 14, 2011
    18
    Thank you Pencil.
    I went ahead and built the circuit as you suggested, but I did not put the 750ohm resistor to the base of the transistor. It did not work... it seems as if the transistor is not saturating, and hence the ground at the emitter not 'opening up'. No current flowing on the main circuit, and zero voltage measured across components. I do have 3,3V out of the output of PIR (confirmed). What is the function of the 750ohm resistor?
    EDIT: I measured the current out of the PIR 3.3V output, straight to ground, and I obtain 2.04mA. Is that the limit of the PIR? And wouldn't I need more than this to drive the transistor?
  17. kubeek
    Sep 20, 2005
    4,691
    806
    Ok, so first try connecting the input end of the 750ohm resistor straight to the 4.5V supply, leaving the other at the transistors base, and see if the LEDs get lit.
    After that, the datasheet mentions an open collector option, are you sure you don´t have this version?
    Pencil: the datasheet say TTL compatible, so there should be some current available with no problems.
  18. Adjuster
    Dec 26, 2010
    2,147
    300
    It may also be worthwhile checking that the LEDs and resistors are correctly connected. If you bridge across the collector and emitter, do the LEDs light?
    Never take anything for granted.
  19. gnolivos
    Jul 14, 2011
    18
    OK, I went ahead and tried that... I fed the base straight from the 4.5V source, and nothing. I did it with and without resistor.
    I am not sure whether it is an open collector version... I did not request it that way, so I assumed I was getting the standard option. Any way to verify?
  20. gnolivos
    Jul 14, 2011
    18
    I bridged it between Collector and Emmiter, and the LEDs light up perfectly and bright. So I know the rest of the circuit is fine.
    I double checked the connections on the transistor, and everything is good. I even read ~ 3V from C to E when using the Motion sensor at the Base. So the transistor is doing something....
    I still believe that the Motion sensor is not able to output enough current to make this work. I am reading about 2 mA from the 3.3V output, when I connect it directly to ground. Is this the right way to read max output?
