Hello
I was trying to understand operation of PLL in transient simulation. I have designed current starved ring oscilator which looks to work well but when I wanted to test the whole locked loop with XOR based phase detector it failed. It is far away from desired refrence clock. When i was debugging it I thought how it should actually work... XOR will give signal based on phase diffrence and this is filtered to give average stable value to drive ring osc. So when we get phase align phase detector will give 0 so ring oscilator will be off (since 0 volts will keep current source nMOS closed). Am I right?
