Basic Op-Amp Question
Discussion in 'General Electronics Chat' started by blackstars56, Feb 14, 2011.
  1. blackstars56
    Feb 14, 2011
    From what I understand from Op-Amps, the + and - input terminals have to ideally have zero current, with infinite resistance. Doesn't that render the Op-Amp useless since no current runs through it? silly question, but i'm confused lol
    thanks
  2. Wendy
    Mar 24, 2008
    20,772
    2,540
    You are talking an ideal op amp, but you have the basics down. Op amps compare the two voltages, and the output swings accordingly. If the positive input is more positive then the negative input then the output swings positive. Basically an op amp (in linear mode) tries to make the voltages on both inputs the same.
    Volume 3 - Chapter 8: OPERATIONAL AMPLIFIERS
    There are many devices that try to use only voltage for the input, and as little current as possible (such as a digital voltmeter). Numbers as low as picoamps or less are routine. A digital voltmeter usually has a 10MΩ input, while modern op amps use much less.
    µa = X10^-6
    pa = X10^-9
    na = X10^-12
  3. Audioguru
    Dec 20, 2007
    9,411
    896
    Many opamps have FET transistors at the inputs that use no input current.
  4. kubeek
    Sep 20, 2005
    4,689
    806
    Bill, you have the two swapped.
    µA = 10^-6 A
    nA= 10^-9 A
    pA = 10^-12 A
  5. kubeek
    Sep 20, 2005
    4,689
    806
    Almost no current, TL071 datasheet states input bias current as 200pA max, so that is input impedance of 5 giga Ohm.
  6. Audioguru
    Dec 20, 2007
    9,411
    896
    A FET has no input bias current. It has a very low amount of input leakage current that increases when the temperature increases.
  7. Adjuster
    Dec 26, 2010
    2,147
    300
    @blackstars56 : What makes you think that an op-amp would need to draw any input current in the first place? In many cases such current is detrimental, which is one reason why the FET input amplifiers mentioned above may be preferred.
    Having a negligible input current does not prevent the op-amp from delivering output current.
