Basic motor controller.
Discussion in 'The Projects Forum' started by gigglewatts, Aug 7, 2013.
  1. gigglewatts
    Aug 7, 2013
    I am about to start a project on my vintage car. I need to make a custom wiper motor for it.
    Basically i need some advice. Maybe a stepper motor or controller plans that i can make to control a stepper motor to +/- 90 degrees?
    Is this achievable with a 12v dc motor, i don't just want to reverse the polarity by switching, i want to do it properly. Are there circuit plans this type of thing?
    A few suggestions would help alot, i want to learn from this so any DIY is valued. Thank you.
  2. strantor
    Oct 3, 2010
    4,302
    1,989
    Stepper motors are going to be a little complicated for this. 12v motor would definitely work, but I don't understand your gripe with polarity reversal. How would one reverse a motor "properly" ? Mechanically, by gearing? I can assure you that polarity reversal is totally legit, not a kludge.
    gigglewatts likes this.
  3. shortbus
    Sep 30, 2009
    4,098
    1,697
    The reversal of wipers is done by the mechanism, not reversing the motor. The motor turns in one continuous direction. See the link; http://auto.howstuffworks.com/wiper1.htm
    I've done what your attempting on quite a few old cars over the years. Both hot rods and just old cars.
  4. MaxHeadRoom
    Jul 18, 2013
    10,867
    2,528
    Have you looked into a modern wiper motor reversing mechanism at the local wreckers?
    I would have thought attempting to modify an existing one would be the quickest solution? albeit, a mechanical one!! :rolleyes:
    Max.
  5. tubeguy
    Nov 3, 2012
    1,157
    197
    Yes, just pick up a wiper motor at the salvage yard.
    Then you can get help here for a speed control.
  6. shortbus
    Sep 30, 2009
    4,098
    1,697
    Back when I was doing them for myself and others, the complete system from a VW bus was the hot set-up. I'd use the whole system and cut the links to make the correct center to center distance on the car in question. But finding a VW bus in a wrecking yard is harder these days.
    The one I'm going to use for the 1937 Ford truck I've been building, came from a Jeep Wrangler. Real close to a VW in size and style.
    In my 1957 Buick Century, I used the Buick wiper linkage and adapted one of these -
    http://www.surpluscenter.com/item.asp?item=5-1791-A&catname=. Took out the original worn out vacuum motor and made a bracket to mount the electric motor in its place.
  7. gigglewatts
    Aug 7, 2013
    First off thanks for the reply. I read somewhere if i were to switch the polarity instantaneously it can stress out the motor, and cause severe heat build up?
    I understand the pulse width modulation, and how it sends timed signals to the stepper motor, i originally wanted to build it. But as someone said here already i could use dc motor and then come back here for details on how to control the speed.
    I want to learn as well but probably i'll take the easiest route, whatever i decide that may be.
  8. gigglewatts
    Aug 7, 2013
    It's a shame these motors only post to usps. Thanks for your reply.
  9. shortbus
    Sep 30, 2009
    4,098
    1,697
    They are available on Ebay and most car/hotrod places sell them. Don't know where you live(should put country in your profile, it helps), but the motors in the link are originally used in heavy equipment, like bulldozers and backhoes or loaders. Try at a sales place for those.
