I have found a few diagrams, and simply can't get anything to work right. I have been working with many different circuits lately, and have been able to figure out almost everything with out issue. I am now losing my mind...
I am looking to use the momentary output output of an lm339 comparator to latch a circuit. I have an LM339 circuit that already has an output based on something else I am doing (< 1sec.). I have been trying to do this with 555 timers, but simply can not get anything to work. At the end, I am basically trying to turn on a relay, and keep it on until another pulse is sent from the LM339 to turn it off. The circuit is run off of 11.1V lithium batteries if you need a voltage reference (9-12.6V roughly between full/dead). What is the simplest way to make a latch circuit that works?
