I was just about to add that to my post #3. Papabravo beats me to it.I think your basic question was why is 3 dB so special?
Well it is because:
\(log_{10} (2) =0.3010\) which makes
\(10 \times log_{10} (2) \;\approx\;3\) and
\(10 \times log_{10} \left ( \frac{1}{2}\right)\;\approx\;-3\)
A lot of information on decibels can be found in the links of this page of the EDUCYPEDIA:
http://educypedia.karadimov.info/electronics/decibels.htm
Bertus
I did not understandA bel is the logarithm (base-10) of the power ratio.
1:1 power ratio is 0 bel.
1:10 power ratio is 1 bel.
1:100 power ratio is 2 bel.
1:1000 power ratio is 3 bel.
There are 10 decibels in 1 bel.
Hence,
1:1 power ratio is 0dB.
1:10 power ratio is 10dB.
1:100 power ratio is 20dB.
1:1000 power ratio is 30dB.
1:2 power ratio is 3dB.
How did we arrive at this?
which makes
and
(with thanks to Papabravo, post #5)
In filter circuits, one wishes to identify the roll-off (cut-off, corner or knee point) frequency in the frequency response curve. When the power is reduced to 50% this is the -3dB point, i.e. the gain is -3dB (i.e. the signal is attenuated by 3dB).
For a voltage V into a load resistor R, the power into the load is calculated as
\(P = \frac{V^2}{R}\)
Hence the voltage drop at the cut-off frequency is 1/√2 = 0.707 or 70%
When the voltage drops to 50% this represents a power gain of -6dB.
(Note that we need to be careful with our choice of words. When someone says "-3dB attenuation" we know what they mean, i.e. a loss of 3dB. Semantically, "-3dB attenuation" means a "gain of 3dB". The person really means to say "3dB attenuation" or "-3dB gain".)
Thanks for your valuable time and information.For a basic RC low-pass filter, the -3dB point has some significant characteristics.
The corner frequency occurs at ω = 1/RC
i.e. \(2 \pi f = \frac{1}{RC}\)
At this point the impedance of C matches the impedance of R.
The resultant impedance
\(Z = \sqrt{R^2 + {X_c}^2}\)
\(V_{out} = V_{in} \frac{X_c}{Z}\)
From this you can see where the 70% voltage drop appears.
The phase shift is -45° at the -3dB point.
Reference: http://www.electronics-tutorials.ws/filter/filter_2.html
actually I was totally blank about this term 3db and it's meaning . I wanted to understand the complete theory of 3db whether it's in terms of gain or loss. I have frequently seen in explain it's Always written -3db that's why I wrote the same.We know what the writer means when they say "-3dB attenuation" but this is incorrect.
Two negatives make a positive. "-3dB attenuation" is literally translated to "3dB gain" but this is not what the writer is trying to express.
The writer should have said "-3dB gain" or "3dB attenuation".
Aha! That is a darn good question.I have no problem understanding the relative meaning of decibels, but I always struggle with the absolute. For instance my home theater receiver dutifully reports the volume setting in decibels. If the wife is out, I can watch a movie at -20dB and have it be gloriously loud. The AV gear heads talk about 0dB being "reference level". What the heck does that mean?
by Duane Benson
by Duane Benson
by Jake Hertz
