Basic Engineering Circuit Analysis 10th Ed., Problem 2.87
Discussion in 'Homework Help' started by jbates, Feb 2, 2011.
  1. jbates
    Feb 2, 2011
    I've been playing around with this problem for a couple hours. I think it might be impossible, so asking here is my last resort.
    Code ( (Unknown Language)):
    1.             + 5V -
    2.  |-------|----R----|-----|
    3.  |       |         |     |
    4. 4kΩ   Is/|\       6kΩ   3kΩ
    5.  |       |         |     |
    6.  |-------|---------|-----|
    Find Is. Is is a current source, btw, in-case my text-art isn't clear enough.
    First, I did the obvious and combined the two rightmost resistors into a 2kΩ equivalent resistor.
    1.             + 5V -
    3.  |       |         |
    4. 4kΩ   Is/|\       2kΩ
    5.  |       |         |
    From the perspective of the node above Is, that leaves two paths to the node below Is where the voltage drops should be the same. Calling the current counter-clockwise through the left loop I1 and clockwise through the right loop I2, Is = I1+I2 and
    5V + I2*2kΩ = I1*4kΩ
    I've tried a million different things from this point, but I just can't solve for Is. I don't think it's possible. This is a new edition of the book and I think this problem must have a typo somewhere.
  2. Jony130
    Feb 17, 2009
    3,990
    1,115
    Is = I1 + I2
    I2 = 5V/R
    I1 = ( 5V + ((5V/R)*2K) ) / 4K
  3. blah2222
    May 3, 2010
    565
    33
    A numerical solution will be determined by R.
    JP
  4. jbates
    Feb 2, 2011
    It's a resistor but the resistance isn't given, only the voltage across it.
    So it really can't be solved with the given information?
  5. Georacer
    Nov 25, 2009
    5,151
    1,266
    I think so too. Is or R should be given. You can always find a solution as a function of one of them though.
  6. Jony130
    Feb 17, 2009
    3,990
    1,115
    If R is unknown, the only think you can do is this
    Is = I1 + I2
    I2 = 5V/R
    Is = 5V/R + ( 5V + ((5V/R)*2K) ) / 4K = 5V/R1 + (5V + 10K/R1) / 4k =
    = (6000 + R1) /(800 * R1)
  7. jbates
    Feb 2, 2011
    Okay, I thought so.
    Well, there goes two hours of my life.
    Thanks everyone.
  8. steveb
    Jul 3, 2008
    2,433
    469
    I agree. You need to find Is as a function of R.
    It's obvious that the value of R is needed because if R=0, there is no solution (Is goes to infinity), and if R is very large then current through R is negligible and the current source has 5V across it resulting in 5V across the 4K resistor and Is is 1.25 mA in the limit as R goes to infinity.
