Basic Electricity
Discussion in 'Homework Help' started by 55bulldog, Dec 26, 2008.
  1. 55bulldog
    Dec 26, 2008
    What is the total resistance in a circuit having 3 feet of 10-ohm/ft wire, with two 15-ohm resistors wired in parallel? I used the formula; Rtotal=R1XR2/R1+R2 & got 7.5ohms. 7.5ohms is not one of the choices for an answer. I went back over the text & did not find anything to help find another answer. I am not sure how nor if the wire length & resistance should figure into the problem solving.
  2. 55bulldog
    Dec 26, 2008
    A Little Help?
  3. bertus
    Administrator
    Apr 5, 2008
    15,806
    2,389
  4. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    Don't forget that there is a series resistance in circuit - something about that wire having several ohms/foot.
  5. 55bulldog
    Dec 26, 2008
    Thanks for the help. I will try to change my posting so that the time stamp will show.
  6. Wendy
    Mar 24, 2008
    20,772
    2,540
    Hint: 3 ft of 10Ω/ft wire is how many ohms?
