basic electric theory (parallel power circuits)
xbox112005
Joined Oct 30, 2011
9
Need help with this question. Two resistors are connected in series.One resistor has a resistance of 1000 ohms,and the other resistor value is not known.The circuit is connected to a 50 v power supply,and there is a current of 25ma flowing in the circuit. If a 1500 ohm resistor is connected in parallel with the unknown resistor,how much current will flow in this circuit?
praondevou
Joined Jul 9, 2011
2,942
50V and 25mA gives you the total resistance. Then calculate the unknown resistor.
You will have 1000 Ohms in series with the value just obtained and 1500 Ohms in parallel. Calculate the new total resistance and then the current.
xbox112005
Joined Oct 30, 2011
9
thanks but how did you get 42
