Basic Elecronic connections
Discussion in 'Homework Help' started by bujingai, Feb 22, 2013.
  1. bujingai
    Feb 22, 2013
    Hi
    Please help me redraw this electronic circuit after replacing the ( Electric Buzzer ) indicated with the letter ( B ) with a 5-pins Electric Relay.
    This is a Laser sensor circuit using a photo cell.
    I would really appreciate it if you guys help me with this one showing the new shape of the new connections after replacing the Buzzer with a Relay.
    Thanks a lot ..
  2. radiohead
    May 28, 2009
    474
    31
    Connect one end of the relay coil to the +9V and the other end of the relay coil to the 8050 collector. Include a reverse-bias rectifier diode across the relay coil.
  3. sheldons
    Oct 26, 2011
    616
    101
    Heres your schematic......
  4. WBahn
    Mar 31, 2012
    18,079
    4,917
    Welcome to the Homework Done For You And Delivered On A Silver Platter forum.
