basic difference between p,i d and pid controller
Discussion in 'Homework Help' started by vead, Mar 29, 2012.
  1. vead
    Nov 24, 2011
    621
    8
    hello
    can anyone tell me please
    what component is use to create p, i, and d controller circuit
  2. steveb
    Jul 3, 2008
    2,433
    469
    PID control can be implemented with one opamp circuit, or with a microprocessor system. In addition, both methods require a measurement system to monitor the variable under control. Also, some type of driver circuit is needed to drive the system.
    I'd go into more detail, but there are tons of books, articles and web sites that give all the details.
    Here are two links ...
    http://en.wikipedia.org/wiki/PID_controller
    http://electronicdesign.com/article/analog-and-mixed-signal/what-s-all-this-p-i-d-stuff-anyhow-6131
  3. MrChips
    Oct 2, 2009
    12,625
    3,451
    In a nutshell,
    P = proportional
    I = integral
    D = derivative
    So, if you are using hardware to implement an analog PID controller, you will need
    P = amplifier
    I = integrator
    D = differentiator
    and finally, a summing amplifier to sum the three signals.
  4. vead
    Nov 24, 2011
    621
    8
    hi
    its mean to implement p controller we can use amplifier circuit,
    integrator for i controller differentiator for d controller
