I appreciate the detailed response. I'll have to read it over. I'm still learning all of my definitions so I'm a bit lost.The effect is that as the loading increases, the voltage of the signal is attenuated within the source.
Think of a power supply which can be modeled with a internal series resistance Rs. As the current delivered to a load increases more current flows trough the series resistance Rs right ?. Ohm states that a voltage will be lost internally on this internal resistance. The effect is that as loading increases the voltage seen as delivered by the power supply (the source) is decreased (think of a voltage divider).
This applies similarly to any 2 parts of a circuit connected together which exhibit a output and input resistance towards each other. As the second part loads the preceding part further the higher is the "voltage drop" due to internal resistance in the preceding part. This is why low internal resistance is preferred in stages "sourcing" signals and high resistance in stages "sensing signals". These 2 parts form a "voltage divider".
Modeled as a voltage divider the second stage measures the signal over it's own input resistance. it is the lower resistor in this resistor divider "model". The sourcing stage is the upper resistor. From this you should realize that if the lower resistor is much bigger then the upper then the second stage will "sense" pretty much all of the signal voltage since most of the voltage falls over the second resistor. As we increase the upper resistance (source impedance) more voltage falls across it and the lower resistor "sees" less of the signal.
Thanks a lot. I appreciate it.Your question relates to TTL chip power supply decoupling. Decoupling via shunt capacitors (which is usually highly desirable if not essential) reduces the induced supply rail spikes inherent with TTL switching technology. Decoupling will also effectively lower the device output impedance - since the chip rail supply side source parasitic impedance will be bypassed to a certain extent.
A lower output impedance is probably desirable in most circumstances. However, as long as one knows what the impedance will be with a given design then the designer can take steps to reduce any detrimental effects.
by Dale Wilson
by Duane Benson
by Aaron Carman
by Jake Hertz
