You said the Vref = 1.49V and Vin=1.5V everything is fine, right?
Before you add 0.5V or 1.5V, please go to measure the voltage of Vin(+), how many volts is it?
Do you have add the 10K to gnd, if you have and then change it to 3.3K or less, I'm afraid that is the current flows out from the (+) of op amp and when the current flows through the 10K and then the Vin will get a as Vin = I*10K, so now you have to reducing the 10K.
