Basic coil help for an idiot
kenw232
Joined May 18, 2009
54
I have a normal coil. I'm going to send a clean 22V @ 1A square pulse into the coil. whatever frequency, say 2 hertz. So the coil will charge and discharge every two seconds.
If I scope the coil it will look like <snip>. How can I keep the integrity of the square pulse high, like if I scope the coil the waveform will look like <snip>. I'm trying to keep the pulse going in (and coming out) as clean as possible. Any tips for a novice? I need to bridge the connectors of the coil with a diode to stop the back emf from discharging back into my circuit right? any recommendations on the proper diode for that? Just seems the more I pulse the uglier the square wave becomes. Maybe I'm not suppose to put the coil on the scope directly, should have a resistor?
Sorry my question is kind of obscure.
Thanks.
kenw232
Joined May 18, 2009
54
I don't really have a schematic. Its just an n-channel MOSFET turning on and off a car battery. works well to light a bulb. straight forward, the bulb flashes because my freq gen is controlling the mosfet with a square wave.
I now want to take that current from the car battery and put it into a coil to create an oscillating EMF field (for experiements and general craziness). I would like to keep the square wave as structured as possible in the coil as it charges and discharges. Like no high voltage spikes or distortion on the edges of square waves. Anything a novice needs to know?
SgtWookie
Joined Jul 17, 2007
22,230
I think that you need to study up on how inductors work.
Inductors resist a change in current. They're sort of like automobiles or railroad trains in that regards. You might stomp down on the loud pedal, but it takes them a good while to get up to speed.
Once they're moving along, they like to stay moving along - like the current in an inductor. Ever try to stop a train suddenly? Ever hit a concrete wall with a car? Not a pretty sight. A similar sort of thing happens with an inductor when it's circuit opens; the current tries to keep flowing in the same direction, but it can't - so the voltage across the terminals reverses and builds to a very high voltage peak. If you've planned for that eventuality, no damage is sustained, and the excess voltage is bled off before it can do damage. If you didn't plan for it, you'll punch holes in things.
kenw232
Joined May 18, 2009
54
right, I need to plan for this stuff. so what is the best diode to stop this backemf voltage spike. any zener will do? I noticed too as I pulse the coil I get an overshoot like in my attached screenshot (I just thew this together to make a point, its not very good). how do I clean up stuff like this?
kenw232
Joined May 18, 2009
54
But for what use? You seem to have specific details 22V @ 1A, 2Hz Square wave. Where did you get these numbers? Why are they important?
I just made it up. I'm working with a bunch of variations of those numbers. I eventually want to increase the Hz in the coil while maintaining waveform integrity, seems the wave breaks down once Hz gets too high. its just for learning and whatnot.
Kermit2
Joined Feb 5, 2010
4,162
What your asking is similar to wanting something almost impossible to achieve.
The nature of physical structures known as an inductor DOES NOT ALLOW SUDDEN CHANGES OF CURRENT.
This will ALWAYS cause a rapidly changing current to be LESS rapid. In other words it will put more slope on the rising edge of your square wave
NO MATTER WHAT YOU DO.
Please read up on the physics and uses of inductors.
I can usually smell an overunity project from a mile away, they stink like moldy cheese.
And in the off chance that Mr. Williams reads this:
Overunity, HHO, Bedini motors, Rodin coils are all scams. They all violate at least one law of thermodynamics. The "inventors" are often uneducated hicks with just enough skills to connect a bag of wires to some coils and a motor (and there's always a battery nearby) and post some useless YouTube video. They're also either outright liars / scammers or poor fools who've convinced themselves they're just that one step away (reality) from overunity greatness (illusion)
Summary, overunity will never ever happen. You always need more energy in then you'll ever get out.
PS the Rodin guy is just plain nuts.
kenw232
Joined May 18, 2009
54
It is not possible. You can have 22v or 1 amp. Not both all the time ( the square wave is high ) Read up on inductors.
ok, I'll read up on inductors I guess. Not sure why I can't have a 22V potential difference moving at 1 amp. The square wave is high? Any clarification would be welcome.
