basic ckt for 24 v to 5 ttl
Discussion in 'General Electronics Chat' started by vigi04, Jan 23, 2010.
  1. vigi04
    Sep 9, 2009
    12
    hi
    i want to know the basic circuit for converting a 24volts supply to 5 ttl..
    thank you..:confused::confused::(:)
  2. bertus
    Administrator
    Apr 5, 2008
    15,806
    2,390
    What current will the circuit draw?
    Can you post a schematic?
    Greetings,
    Bertus
  3. SgtWookie
    Jul 17, 2007
    22,183
    1,729
    Do you mean that you wish to power a TTL-level 5v circuit from 24V?
    Or do you wish to know if 24V is present or not by testing from TTL level?
  4. Papabravo
    Feb 24, 2006
    10,340
    1,850
    The LM393 or LM339 work very well in this application. You can configure it as a buffer or as an inverter. You do need to watch your common mode voltages however.
