Yes, the power requirements I am referring to is the resistor wattage rating.Thanks iONic. Could you give more details. When you refer to Power Requirements, are you referring to the Watts. I see that there are several different wattages available starting at 1/4 watt and going up to 1 watt. What does IsqR stand for and is that the formula after that (.02x.02)/R.
Thanks.
"IsqR" was my way of giving you the equation for determining the power consumption for the resistor... It's the current squared x the resistance as in the following image:
