BASIC, C, and an ATMega328
Discussion in 'General Electronics Chat' started by Metalfan1185, Mar 29, 2009.
  1. Metalfan1185
    Thread Starter Active Member
    Sep 12, 2008
    I have a question for the board...
    I recently purchased an Arduino Atmega328 Board. This is programmed with what seems to be C. I don't know C, but i Do know how to code with BASIC. IS there any way to say, write code in BASIC and somehow convert it into C before it's written to the chip?'
    If so, will this work for Java Code as well?
    My interests receently are Programmable MCU's and I was thinking of useing Java to write a few apps for my Google G1.
  2. hgmjr
    Jan 28, 2005
    Programming in C-language is a really good skill to acquire. It is not terribly difficult and there are a number of good sources on the Internet that you can use to help you overcome any snags you might encounter.
    Maybe this is a good time for you to use the Arduino board as an opportunity to get acquainted with C.
  3. thatoneguy
    Feb 19, 2009
    There are BASIC compilers for the AVR series, ranging from $50 to $500. They do NOT produce C output, but usually an assembly listing and the binary to load onto the uC.
    If you are determined to learn C, start with the Arduino, which hides a lot of the 'harder parts'.
