Basic BJT circuit analysis
Discussion in 'Homework Help' started by Cyberduke, Apr 2, 2016.
  1. Cyberduke
    Thread Starter Active Member
    Mar 5, 2011
    33
    Hi I am doing basic BJT circuit analysis and my lecturer has uploaded some example problems for us to do. We can give an answer and it will get marked automatically. But we are only given a mark for each question, not a correct answer.
    I have been over my answers a few times and I am struggling to see what is wrong. Attached is the quiz and the method I followed at each question (except for the first two questions). If someone could help point out what I do wrong I would appreciate it very much. Next to each question is the mark I got for that specific question.
  2. MrAl
    Distinguished Member
    Jun 17, 2014
    2,567
    521
    How do you approach a transistor problem like these, do you use a current controlled current source to replace the transistor or some other idea?
  3. WBahn
    Mar 31, 2012
    18,091
    4,917
    What's your rationale for each of your answers in the first problem?
    In the third problem, how do you get a base voltage of 1.7 V? Does this make sense? In a PNP transistor, is the base at a higher or a lower voltage to forward bias the base-emitter junction?
  4. Cyberduke
    Mar 5, 2011
    33
    Ahh I see, the Vb in question 3 should be 0.3V. I missed that, thank you.
