Basic BJT amplifiers
Discussion in 'General Electronics Chat' started by full, Oct 3, 2014.
  1. full
    May 3, 2014
    225
    Hello everybody,
    I study basic BJT amplifiers , and I can change the DC Bipolar Junction Transistor to AC Bipolar Junction Transistor......
    but there is problem I don't know how I can do loop in AC Bipolar Junction Transistor....
    please can you help me, how I can do loop in this circuit AC?
    thanks,
  2. alfacliff
    Dec 13, 2013
    2,449
    428
    there is no ac bjt, BJT refers to bipolar junction transistor, not bipolar. have you read your thread on bjt posted on monday? the bipoolar refers to n type and p type materials, not an ac operated transistor. transistors operate off dc, not ac.
  3. full
    May 3, 2014
    225
    thanks sir,
    if I change the (npn common emitter) Bipolar Junction Transistor figure 6.28 to figure 6.29 , what is mean?
  4. alfacliff
    Dec 13, 2013
    2,449
    428
    the first one is the schematic reperresentation, how the circuit is built, the second is the mathematical representation.
  5. full
    May 3, 2014
    225
    nice ,
  6. Jony130
    Feb 17, 2009
    3,990
    1,115
    In figure 6.29 you have a small signal mode . A DC circuit that represent/simulates the behavior of the transistor for AC signals.
    So simply use a Dc network analysis techniques. For example a KVL ; nodal or mesh and solve it.
  7. full
    May 3, 2014
    225
    thanks sir,
    please can you do KVL for figure 6.29...
    because I when understand how I can do in another time ......
    thanks ,
  8. full
    May 3, 2014
    225
    what happen if I change from figure 6.28 to figure 6.29?
    why I change the circuit from figure 6.28 to figure 6.29?
    thanks,
  9. full
    May 3, 2014
    225
    why in circuit figure 6.33 (gm v-bi) and in figure 6.28 (B vb)?
    thanks,
  10. full
    May 3, 2014
    225
    now I understand :)
    thank you
  11. full
    May 3, 2014
    225
    the AC analysis circuit in figure 6.33 very difficult :confused:
    please can you help me how I can see the circuit and analysis?
  12. full
    May 3, 2014
    225
    I have small question, what different between (gm v-bi) &(B ib )?
    what meant by transconductance ?
    when I use (gm v-bi) and (B ib ) in circuit?
    is mean the (gm v-bi) = (B ib ) same in calculation?
  13. Jony130
    Feb 17, 2009
    3,990
    1,115
    Hi, do you know anything about dependent sources ? Because we can model/represented the BJT in two equivalent ways.
    Ordinary we treat BJT as a current controlled current source. The collector current is beta times the base current Ic = β * Ib.
    And the current gain is β = Iout/Iin = Ic/Ib
    http://forum.allaboutcircuits.com/threads/common-emitter-amp-doubts-and-questions.91084/#post-663195
    But sometimes we use alternative equivalent model but this time transistor is represented as a voltage controlled (Vbe) current source (Ic).
    So the gain is equal to Iout/Vin = Ic/Vbe = transconductance = gm in unit, Siemens (S)
    gm = Ic/Vbe and also notice that Vbe = Ib * rpi.
    gm = Ic/Vbe = Ic/(Ib * rpi) = β/rpi
    http://www.ittc.ku.edu/~jstiles/412/handouts/5.6 Small Signal Operation and Models/BJT Small Signal Parameters lecture.pdf
    http://www.ittc.ku.edu/~jstiles/412/handouts/5.6 Small Signal Operation and Models/Steps for Small Signal Analysis lecture.pdf
