we have a 24V dc circuit. To allow for one action when teh power is switched off i thought about placing a 24V battery in series with the rectifier output using the rectifier circuit to charge the battery
As the float value of the transformer circuit appeard to be 37V dc. Do I need to regulate reduce this? if so how,
Could I use just a capacitor between 24V and oV? if so how do i decide on type and size. I want to operate a solenoid for a lowering valve for 30 seconds and a coil in a solenoid lock for a further 20 seconds. strady state 4VA, start inrush 60VA
I have previousely used charger, battery and realy and delatching switch which is a littl e complicated
many thanks
many thanks
