Basic Audio Project Help
Discussion in 'The Projects Forum' started by ComputerGeek, Jul 12, 2011.
  1. ComputerGeek
    Jul 12, 2011
    Hello, my first post. Yay :) Anyway, I have a question I want to use a peizo as a pickup in a circuit where there was previously a Electret condenser microphone or a dynamic mic (not sure which one). Anyway, I heard that a Peizo was a high-Z signal and was wondering if I could just exchange these or if that would fry my circuit without converting it into a Low-Z signal. Any help would be great.
  2. Kermit2
    Feb 5, 2010
    3,847
    963
  3. ComputerGeek
    Jul 12, 2011
    I Read most of it, however it is a little over my head. I should give a little more info about what i am looking to do,
    This will be going into a Bluetooth Headset. So what I am looking to do is remove the current Microphone and replace it with a peizo. are you saying that I will need a preamp for the peizo since it is High-Z?
  4. Kermit2
    Feb 5, 2010
    3,847
    963
    you could try a direct input replacement. If it is too weak to give a suitable output compared to the original microphone, a simple variable gain opamp circuit might be all you need to adjust the response level.
