Hello all. I am halfway through Stan Gibilisco's book on "Teach Yourself Electricity and Electronics" and am curious about a particular amplifier circuit.
Q1: What exactly is the "input"? Can this be a microphone, for example? And if so, wouldn't a microphone generate "pulsating DC" rather than AC? I always thought that microphones, and similar devices (say, for example, a photodiode) simply allow more or less current to pass through them based on a given input. A sort of variable resistor, if you will. But, as explained in the text, it is evident that AC, not pulsating DC, is required, and I thought the two were different.
Q2: The voltage at the gate affects the current at the drain. But supposedly this current at the drain is DC, yes? Then why does the book mention that the capacitor at C2 allows AC current to pass through it? Where does the AC at the drain electrode come from? As you can see in the attached diagram, +12V is connected in close proximity, and no sign of AC current to be found.
I believe that is the real source of my confusion -- I do not know where the alternating current (AC) is coming from. I understand capacitors allow AC to pass, and inhibit DC, but if you've got a microphone at the source, then you're just getting pulsating DC, right?
And furthermore, even if there were AC around the input region, it seems to me that all a JFET can do is either increase or decrease the current from source to drain -- it should not generate AC. So why put a capacitor at the drain? Is the transistor really generating AC? Seems to me it should only allow DC to flow from source to drain, since the source is supposed to be negative, and the drain positive.
