how does base currrent remains constant and what makes it to be constant?A transistor needs base current for it to turn on. But transistors even with the same part number have different amounts of current gain and different amounts of base-emitter voltage so a voltage divider is used to feed bias current to the base and an emitter resistor is used to reduce the variations among transistors.
by Jake Hertz
by Aaron Carman
by Jake Hertz
