Dear all,
I know that there is a need for a resistor to be connected between the pin out of a PIC and the base terminal of the transistor. The resistor is to limit the base current and prevent the transistor from damage.
So exactly how much base current will damage the transistor? is it indicated in the datasheet of the transistor?
I saw in the BD679 datasheet that puts Base current = 1A. Does it mean that 1A supply to the base terminal will damage this transistor?
Kindly advise.
Thanks alot!
Kindly advise.
Thanks alot!
